Use this procedure to configure the query maximum response time for mld interface.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface vlan <1–4059>
  2. Configure the query maximum response time for mld interface:
    ipv6 mld query-max-response-time <0–60>
The following table describes the variables for the ipv6 mld query-max-response-time command.
Variable Value
<0–60>
Indicates the query maximum response interval time in seconds.
